06-12-2025 09:55 PM
Just subscribed to public mobile. Trying to transfer number but can’t log in as it was trying to say for Koodo subscribers. Cant even get far as to submit a ticket. Just paid almost 40 bucks for this and it’s already making me regret I bought this.
06-12-2025 10:19 PM - edited 06-12-2025 10:37 PM
@Synnnntax try to reboot the phone and login again and see if the process pick up at Step 6 and can complete the activation
And still try to put the sim into the phone and see if it works
if the above does not help, you will need to engage support by direct message at:
06-12-2025 10:14 PM
06-12-2025 10:14 PM
I chose a number now it’s telling me something went wrong with the activation. What a service!!!!!!!!
06-12-2025 09:57 PM - edited 06-12-2025 10:09 PM
did you pick a new number during subscription? If so, can you confirm if you can make calls on your PM sim?
or did you request porting during subscription ? If so, and if your Koodo account is Prepaid, you will have to choose a new number first. You will have to activate the account with the new phone number, then open a ticket with PM support and ask them to help to manually port the number from Koodo prepaid account.
To open ticket with PM support after the account is activated with the new number:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
