04-20-2026
08:23 PM
04-20-2026
11:38 PM
computergeek541
04-21-2026 09:43 AM
Hello @ georgeakcj,
Please check your inbox. An agent replied to you in a private message and is waiting for your response in order to assist you.
04-20-2026 08:25 PM
There is a number to call to talk to live support, they can confirm the porting status for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
