08-10-2026 03:48 PM
08-21-2026 02:53 PM
All good thanks
08-21-2026 02:53 PM
Yes all good thanks 👍
08-19-2026 08:09 PM
Yes All good.... thanks
08-10-2026 03:55 PM
hi @MikeDoerr
transferring in to Public Mobile?
Did you get a text from the old carrier, did you reply Yes within 90 mins? (Make sure you have your old carrier sim card /esim still in the phone so you can receive the text and reply)
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
