07-01-2026 08:58 PM
Tried to scan the QR code but it expired. cannot get my phone to work. What should I do?
07-01-2026 09:41 PM
open setting s to see if the esim is actually there already. If so; disable your old esim and set Public Mobile as the primary. Restart cellphone
07-01-2026 09:40 PM
hi @Mima450 you meant the eSIM QR?
you have problem with it because the eSIM already installed by the app
make sure you disabled your old carrier sim card or disable old eSIM
make sure your PM sim is enabled and set as Primary. Reboot your phone and Reset Network Settings and it should work. Try both inbound and outbound calls and data
