12-22-2023 05:05 PM - last edited on 12-22-2023 09:57 PM by computergeek541
12-22-2023 06:22 PM
@BKNS27 Physical SIM cards are free right now for new activations
12-22-2023 06:15 PM - edited 12-22-2023 08:48 PM
You need a SIM first before porting over to PM. They are $10 at a Telus/Koodo/Monile Klinik or $4.99 at Amazon but there are rumours they will be free on Boxing Day.
12-22-2023 05:28 PM
did you try searching the “get help” section, there’s an article dedicated to that (near the bottom, it specifically discusses porting from Koodo prepaid)
https://www.publicmobile.ca/en/ns/get-help/articles/transfer-your-number
12-22-2023 05:12 PM
If you haven't done so yet, go on the website and pick a plan. Great offers on there. Download the public mobile app to your phone and activate the plan. Once you are done doing that, contact the below for the rest of the transfer of you numba.
12-22-2023 05:08 PM
Hi @mekola
The transfer from Koodo to Public Mobile is a little tricky and usually requires extra assistance.
If your Koodo service was pre-paid, you need to contact the customer service team to transfer your number once you have created an account with temporary phone number. Here is the link to write to them:
Please be sure to explain the issue to them. They will respond to you in your community inbox so check it from time to time. (Little envelope icon on the top-right of this page).
If post-paid you will need to contact the Porting team for assistance. They will re-trigger the porting request for you and fill in any gaps. I’ll send you the porting team number via private message. You will find the number in your community inbox shortly using this link:
12-22-2023 05:07 PM
You can message a customer service representative at the link below to transfer you numba.
12-22-2023 05:07 PM
hi @mekola
For Koodo Prepaid, you will need to activate a PM account with a new number first.
After the account is fully ativated, submit a ticket with PM agent and ask them to manually port your Koodo phone number for you.
yuu can submit ticket with them here when it is ready
12-22-2023 05:06 PM
@mekola Submit ticket with support and they can transfer the number for you
send a private message To CS_Agents
