10-18-2024
12:58 PM
10-18-2024
05:08 PM
computergeek541
10-18-2024 02:31 PM
The support agent was finally able to complete the transfer procedure for me. Phone is finally working. Thanks for the help
10-18-2024 01:02 PM
hi @Marie33
can you make outbound calls? data work? if nothing work, it is not a transfer problem but account setup. Please ask PM support agent to check, submit by direct message:
10-18-2024 01:01 PM
try reboot the phone. If still not working, ask PM to help. Since your line is not working, I don't think you can submit a Chatbot ticket, so , just message them:
10-18-2024 01:01 PM
@Marie33 Have you tried rebooting the phone ? Try that first and test . If you need support here’s the link for them
