03-10-2024
11:48 PM
03-10-2024
11:51 PM
computergeek541
If I want to transfer esim from the older phone to new one. How could I do that?
03-11-2024 11:45 AM
03-11-2024 11:41 AM
Hey
just go into the settings> cellular then go to esim option and there will be option of transfer into other phone. That would work.
03-10-2024 11:52 PM
@SparklingZzz You need to download the app on the new phone . Log into your account and re buy the eSIM from subscription add on page . Notice “shop SIM card now “ tap it and choose eSIM and install . That’s it .
03-10-2024 11:51 PM
For eSIM with new phone, you have to re-buy a new one for $5.
Yes, while eSIM is "cool", there are disadvantages as well. For eSIM, if you have a new phone, or if you ever wipe your phone, you will have to re-buy a new eSIM again. There is no such problem with Physical sim card.
To rebuy new eSIM, First, download the app on your new phone, click ⊕ or ⧁ at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now. You can buy and install eSIM from there
03-10-2024 11:51 PM
@SparklingZzz wrote:If I want to transfer esim from the older phone to new one. How could I do that?
Sorry, but there is no option for this. A new SIM or eSIM will need to be purchased.
