Top up
Joshua2026Futur
I have $40 in my available funds, but my data is at 100%. Please reset my plan cycle immediately." How to fix this issue
slusagm
@Joshua2026Futur
for early renewal,  you can ask PM to help.
but a quicker way is to get another plan.  Go to My Account->Change Subscription and pick another plan and you can use Change Now to make an immediate change.  If you only have $40 and not expect PM to charge you more from credit card, you need to pick a plan that is $40 or less
hi @Joshua2026Futur
did you contact PM support for assistance with early renewal?
hi @Joshua2026Futur
can you login to My Account? do you see the $40 (pre-tax amount for $44.80) shows up as Available funds?  If so, the $40 is there, you just need to ask PM support agent to help to renew now
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
