06-13-2026 10:42 AM
06-13-2026 10:52 AM
PM can send you an unlock code
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
06-13-2026 10:49 AM
If your SIM card is locked, you will need to contact customer service agent:
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
