Top up not working
Rooey
I bought a 1 gb top up yesterday after I used all my data but I paid for it and it's not working - what am I doing wrong?
7 REPLIES 7
hi @Rooey
you clicked "Usage breakdown" on the page and still cannot see the add-on?  Submit a ticket by direct message then
Rooey
Thanks - I bought the add on - see it in my purchases but can't see it anywhere else - tried incognito - just shows that my monthly plan data is all used but can't find the add on?
and @Rooey
are you in GTA area? you can be impacted by this active issue:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Active-Degradation-of-Wireless-Service-in...
@Rooey
i would ask PM to check.  Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
hi @Rooey
first, check if the data addon still there.  using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in), click Usage Breakdown under the Usage odometer on the front page and check if the data addon still have data left
If it has, reboot the phone first.  And make sure you don't have data limiter set, disable it.  Then try using the data
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Rooey
THANK YOU!  Did that - it did not work...
slusagm
Try reboot the phone and test again
