Toll free calling and add-on plans
thomask
If I call a toll free number, will it affect my add on available minutes?
I’m inside Ontario, calling Bank of Montreal toll free number on the MasterCard for example.
7 REPLIES 7
choding
you should use Fongo app is free call in Canada.
I had wide province call plan. At that time I use this app.
It use wife or data for call so that you don't need to pay anything else.
good luck.
As you're on a Province-Wide plan, if you were not able to call that number, it would not have connected.  Remember, other than the limited 50 min talk / 50 SMS/MMS plan, you are not 'charged' for calls if you have unlimited calling and/or LD addons.
srlawren
I'm fairly sure NANP in this case stands for North American Numbering Plan.
thomask
Good to hear...  I stood for 35 minutes on hold with the toll free so it was a concern.
that said, this is the usage history on the account...
ONTARIO NANP area 0:33:37 Minutes $0.00
not sure what NANP means but it was the destination...
@thomask wrote:
Province wide unlimited, unlimited global texts, 1GB data.
Yes the 1-800 shouldn't require LD addon.  I am sure I have called some and haven't noticed it using my long distance addon
thomask
ShawnC13
What is your plan?  If you are on the $10 50 minute plan ues it will count for your minutes.  If you are on a Province wide or this should not affect long distance addon minutes.  If you have Canada wide calling no worries at all.
