03-03-2023 07:58 PM - last edited on 03-04-2023 11:26 AM by Dunkman
03-04-2023 11:28 AM
US roaming talk is hit and miss at the present time with Public mobile. Try to connect to T mobile network for voice.
The issue with Public mobile US roaming at the present time is the decommissioning of 3G Networks in the USA.
According to Public mobile,
PM will have T mobile 2G network for US roaming.(for talk)
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
Public mobile is working on a long term solution, but that will take time.
Here is some more info:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
03-03-2023 09:55 PM
You can create a ticket through chatbot about your issue and staff will reply you through private community inbox. Make sure you login and check back the inbox. (There was no email indicate to you when they reply)
03-03-2023 08:54 PM
It is a voice issue. I can now text but I can’t call home to Canada from Florida . I bought the US talk and text for 15 days plan. I guess I’ll wait till tomorrow to see if they fix it. Thanks for the help.
03-03-2023 08:22 PM
@Lizblad what is the issue you are facing? do you mind to share?
if it is about voice issue,
PM confirmed the voice issue and is working on it
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Service-Impacts/td-p/955119
But to open ticket, here are the 2 ways
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
