Ticket not working
Mi6
tried to submit tickets so many times . Phone calls can’t last more than 2 minutes and I have to call back  4 more times.. worked fine until last week or so. If I can’t solve it and can’t do ticket will have to look elsewhere for service.
7 REPLIES 7
@Mi6
Do you know if you are using 3G for VoLTE for calls?
  • change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
  • Try to click Reset All Networks and see if it helps
  • and do you have another phone to test the PM sim ? just to make sure it is not a device problem.  Also, that can force a sim card re-provision and it could resolve the problem
  • Also, try the phone in another area if possible, it could be just a local network outage
  • You can also try to see if VoLTE works.  But first, what brand and model of phone you have?
    You can check the VoLTE compatibility here:  https://www.publicmobile.ca/en/on/get-help/articles/volte
    If you have a compatible one try to turn on VoLTE
    iPhone: Likely no extra work need to do as Telus will enable by default but hide the option.  Still you can check
                     Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
    Pixel:  Likely no extra work need to do as Telus will enable by default but hide the option.  Still you can check
                    Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
    Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
    Now, turn off Wifi first. Check if the phone status bar showing it is connected to 4G or LTE
    Then make some calls, see if the signal indicator shows LTE or drop back to H or 3G while you are on the calls.  If it stays with LTE, then yes, you are using VoLTE, and you can see if calls are any better.
Mi6
No just my regular local calls
Mi6
  • All numbers
dust2dust
Is this possibly roaming with the add-ons in the states?
OP did post their issue @softech
@Mi6 does this happen with calls to all numbers or just a specific one?
Sounds like you may need a re-provision of your Sim card – hopefully you can get a ticket processed and request this of the customer support agents.
@Mi6  Chat box doesn’t always work you can send direct message to support here
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
@Mi6
please use this link to direct message support instead:
and maybe you can share your issue and we can try to help??
