03-25-2024 10:09 AM - last edited on 03-25-2024 04:35 PM by computergeek541
Hello there,
Last week I got 240GB as rewards for 150 days. But today I checked they are gone from my account.
This is the message I got from you last week:"Public Mobile here, delivering on our promise. We've successfully added the 240GB of bonus data to your account as a thank you for your continued loyalty. This bonus data will expire in 150 days. Enjoy the extra data and thank you for choosing Public Mobile."
Please, may you told me what's going on.
03-25-2024 10:34 AM
thanks a lot for that clarification. Highlighting the fine print was super helpful and clear : )
03-25-2024 10:30 AM - edited 03-25-2024 10:32 AM
You won’t lose the bonus data if the plan you want to upgrade to is more expensive.
03-25-2024 10:27 AM
I received that same message, and thought, "great."
But then yesterday I was going to upgrade my plan, but didn't because it said i would lose the rewards. That doesn't really make sense to me, especially since i wanted to upgrade, not downgrade. : (
03-25-2024 10:26 AM
You will lose the bonus data if you downgrade from your current plan but it will remain if you upgrade your plan.
There was many reports of members downgrading and lost the bonus data.
You can try contacting a CS_Agent on the Chat button and type in Submit a Ticket but I doubt if you can get it back.
03-25-2024 10:22 AM
Yes, I changed the plan. But that doesn't make sense. Because, I wasn't using my plan data, so I changed the plan to be able to use the rewards.
Plus, I didn't get message told me I will lose the rewards when I changed the plan.
03-25-2024 10:14 AM
If you did change your plan after receiving loyalty bonus then it is GONE.
Use fresh browser, incognito and check status again. If you saw it once it has to be there unless you change plan.
