11-02-2018 09:49 PM - edited 01-05-2022 02:23 AM
Hi,
I am completely aware that checking voicemail from that $10 plan phone deducts in-plan minutes.
Can someone confirm if checking voicemail from other phone (by calling that that $10 plan phone# and press '*') also deducts minutes, or not?
Thank you!
01-10-2019 01:22 AM - edited 01-10-2019 01:22 AM
You can also get around using minutes with the call forward trick
Works no issues with sending or retrieving voicemails
01-08-2019 09:44 PM
@RossN wrote:I can only speak for the 10 dollar plan but yes they do charge when someone calls your voicemail at least they are with mine it seems anytime someone calls trying to sell ya something or tell you your in trouble with the taxman haha you are charged minutes, very annoying
There are two places that show calls:
1. the overview page
2. the usage pages
The first one is the one that reflects your consumption. You should not see that number increment when someone leaves you a voicemail message. You *will* see the record of the call in the usage pages.
This may not be written, declared policy...but it is reality.
01-08-2019 08:50 PM
11-03-2018 03:04 PM
No, the FAQ is unclear. You use minutes in your plan if you are calling from your mobile phone and you leave a voicemail on someone else's mailbox.
If someone is calling your mobile phone, and you don't pick up and it goes to voicemail, your minutes on your own plan do not get used.
11-02-2018 10:04 PM
Thank you for your reply.
One more question.
According to this post https://productioncommunity.publicmobile.ca/t5/Announcements/Plan-updates-new-10-limited-talk-and-te... , so if people call me and leave a message, it will deduct my minutes, correct?
11-02-2018 09:56 PM - edited 11-02-2018 09:58 PM
From experience it doesn't and that is how I used to go around that when I was on limited voice plan back in the dayz
11-02-2018 09:56 PM
Hi @drsiha, Calling in to check your voicemail from a land line, or another phone of any kind does not use your plan minutes.
Welcome to Public Mobile.
