07-13-2022
10:06 AM
07-18-2022
10:24 AM
Dunkman
Your website is down and for the last 3 days I haven't been able to send or receive texts. Calls and wifi and data appear to be working fine but when I send a text it says failed. I have restarted cell, done airplane mode, cleared message cache. Trying to determine if the issue is on my end or yours
07-13-2022 10:14 AM
Try to reseat your sim (power off, take sim out for a minute and then put it back and power up)
If still fails, try to download another text app and text there. Maybe Google Message
07-13-2022 10:12 AM
I already cleared the cache and only own one cell. Started a few days ago so trying to determine if its somehow related to Roger's crash. It will send maybe 1 in 5 text attempts
07-13-2022 10:09 AM
@Tabitha17 Hi try turning off your phone take out your Sim card, reseat it and restart phone
07-13-2022 10:08 AM
@Tabitha17 Try to clear cache on your phone's messaging app
Also, if you have another phone around , try to put the PM SIM in the other phone to test the SMS there
