08-23-2022 09:19 PM
Most times when I send a single text .. the person will receive it multiple times.. sometimes up to 6
I have restarted my phone, tried to switch to a next TXT app (textera). All without any success ..
It does not happen all the time
08-26-2022 12:25 PM
I used to have google messages app but read somewhere that it can cause this problem so switched to textera.. normally the people i send to are not in same house .. but within 5 k .. I can try the RCS change
08-23-2022 11:06 PM
@Barboj2 Try the Google Messages app. Make sure you don't enable RCS. Whenever the other party receive duplicate texts, are you near the same location by any chance? How is the signal level when this issue occurs?
08-23-2022 10:15 PM
Happens various times to most of my contacts
08-23-2022 10:14 PM
This has been going on for a few months now so not sure how much longer to give it
08-23-2022 10:14 PM
This I have tried with the standard android message app. I read somewhere about textera maybe being better but not much change
08-23-2022 10:13 PM
Thanks I'll try this
08-23-2022 10:02 PM
@Barboj2 Try to clear cache first
also, the duplicate messages issue, does that happen to only one recipient ? or it happens to different people you sent to?
08-23-2022 10:01 PM
@will13am wrote:@Barboj2 , could the multiple texts be due to conflicts between textera and the stock SMS app? Whichever app you are using as the default text app, please force close the app, delete app cache and relaunch the app.
There could also be an issue with the text messaging intercarrier intermdediary. I suspect that this issue might fix itself over time.
08-23-2022 09:59 PM - edited 08-23-2022 10:00 PM
08-23-2022 09:36 PM
and rebooting device.
still same issue then contact support team by > CS_Agent to check it your account.
08-23-2022 09:29 PM
Motorola moto
08-23-2022 09:21 PM
what device brand and model you use.
