Texting
Darren632
Why can't I send or receive picture messages?
7 REPLIES 7
@Darren632
try to Reset All Networks and see if it works first
Darren632
Ulefone.when I open public mobile I don't have the option to change anything
@Darren632 yes. Please try manual change
and what phone you have??
Darren632
So I need to change these settings manually?
Darren632
Yes
@Darren632
Not sure if your phone is affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Jess31
Do you have mobile data turned on? You need to have that on.
