02-18-2024 06:28 PM
Just bought Ulefone 16 Note Pro, cannot send or receive Photos/pics when texting! Works fine with email! Any suggestions, please.
Phones
02-19-2024 11:10 AM
Here is some additional information:
https://publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
Check your APN settings.
02-18-2024 07:16 PM - edited 02-18-2024 07:18 PM
@Chalupa_Batman wrote:Did you just port over your number from another service? Or did you just swap out your PM SIM card into this new phone?
Number porting would have no effect on outgoing MMS messages (which this customer isn't able to send), nor would a number porting issue prevent only receipt of MMS (SMS wouldn't come either if it's sent from a different carrier).
02-18-2024 06:55 PM
Guess that didn't work!
02-18-2024 06:55 PM
Inserted SIM PM Card from another device (Motorola) Same number had it for years!
02-18-2024 06:50 PM
Tell us more what you did/do.
When did you signed up with PM? Did you port your number? Does other services work as expected? Can you call out, receive calls? Can you do SMS in/out?
For MMS to work your DATA has to be ON. MMS will not use your data allowance, though...
DO NOT USE 3rd PARTY apps for MMS! Use native phones texting app.
02-18-2024 06:36 PM
Hello @Wijou2
02-18-2024 06:36 PM
Try the following…reset network settings, ensure apn settings are correct, ensure cellular data is on.
