09-22-2022 10:52 PM - last edited on 09-22-2022 10:55 PM by computergeek541
When I’m not using wifi and using cell data, I am unable to receive texts or it takes a really long time (10 min)
09-22-2022 11:26 PM - edited 09-22-2022 11:27 PM
Just an FYI Telus call centres for example....
Hours
Monday to Sunday:
9am to 7pm
Please note:
We may be unable to accept calls placed near closing as we serve the remaining customers in the queue.
Otherwise you get to talk to their chatbot or use their community which may take you a few days to get an answer if you get an answer at all. Whereas at public mobile you will find someone in the community to help you 24/7. It may take you 10 minutes to get someone to help out at 3:00 a.m. but you will get a response from a live human being any time of the day.
09-22-2022 11:23 PM
@rory5 wrote:If I can’t speak to a support person regarding my issue, gonna switch carriers where I can speak to a live person when needed.
@rory5 - if you do not rule out the phone or plan first I don't feel customer support will help you any better.
But, you can find customer support contact methods in the Get Help section:
Or, go to the bottom of the community page and find 'Chatbot (SIMon)'.
09-22-2022 11:18 PM
@rory5 Sounds like your daughter is out of her 1GB plan data.
Unless she has never been able to use data before. Has she been able to use data and texting outside of wifi previously? I'm a bit unclear about that.
If she does have data remaining - Perform a Reset of the device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If she doesn't have data left, she will need a data addon, or change plan or renew plan early if she needs data.
Or wait until the plan renews to replenish the plan data.
09-22-2022 11:17 PM
Is mobile data enabled? Did you update the carrier profile when you got the iPhone?
09-22-2022 11:10 PM
Log in to her account and click on the little spinner refresh icons lower down and see if there is in fact data left. Or use private mode.
09-22-2022 11:08 PM
My daughter is unable to receive texts when using cellular data. She has 1GB remaining, acct is in good standing (she receives texts as soon as wifi is turned on), SMS and MMS on her new iPhone are enabled. Tried to send a text in our home which has a strong signal with no success. If I can’t speak to a support person regarding my issue, gonna switch carriers where I can speak to a live person when needed.
09-22-2022 10:56 PM
Both iMessage and Chat Features require a wifi connection or data to send/receive texts.
Disable your Chat Features:
09-22-2022 10:55 PM
@rory5 wrote:When I’m not using wifi and using cell data, I am unable to receive texts or it takes a really long time (10 min)
This could be an issue of weak cellular signal. SMS Text mesaging doesn't use Wi-Fi or mobile data. You can disable iMessage or Google's chat feature to see if that helps.
09-22-2022 10:54 PM
iphone? Do you have data left on your account?
