Texting out of province
Carole8
I have Canada wide texting - jut arrived in Labrador, can’t text! Does that mean I can’t text out of province? Thanks!
JL9
Are you getting a message or is it just continually hung in a loop?
RossN
@Carole8 hi are your other services working,data, calling ?
@Carole8
Yes you should be able to text Canada wide. Check to Network Selection is it us on Public Mobile.
Depending where you are located in Labrador, there maybe no coverage in your location.
Check coverage Telus coverage map:
https://www.publicmobile.ca/en/bc/coverage
Remember
@Carole8
trying add +1 and reboot phone.
You can text anywhere while in Canada @Carole8 with inmarket plans.. (unless you are on an old text plan).
Try restarting your phone.
