Texting issues
03-22-2019 01:35 AM - edited 01-05-2022 03:52 AM
So I have have been using PM for two days now and have been having a new to this phone issue with text messaging. I will be unable to send any texts my program ( messages) tells me that there is " no sms connection" it shows an icon of a cloud with a line thru it. It will stay this way until I restart my phone. I receive no warning about the lack of connection I also still have full bars.
My Account
03-23-2019 10:34 PM
So this issue has been solved.
I reset to default the APN's and it appeared to solve the problem. I am no longer having that issue. texting and phone work as they should.
03-22-2019 06:44 PM
@frankindustries wrote:Also I should mention that after I restart I am able to text and receive calls normally. Also intermittently I will be unable to make a voice call or text.
I suspect an app is interfering somehow since you say it works after a restart. Try turning off/disable apps one by one and see if there's a culprit.
Or an antenna problem.
Did you try the SIM in another phone as suggested?
03-22-2019 06:39 PM
03-22-2019 10:19 AM
Thanks for the help, I have updated my SMSC, so hopefully this will solve my issue. Unfortunately I am unaware of what triggers this event so I will have to wait for today to see if the issue happens again.
03-22-2019 03:16 AM
@frankindustries wrote:So I have have been using PM for two days now and have been having a new to this phone issue with text messaging. I will be unable to send any texts my program ( messages) tells me that there is " no sms connection" it shows an icon of a cloud with a line thru it. It will stay this way until I restart my phone. I receive no warning about the lack of connection I also still have full bars.
Try your sim card in another phone does text messages work? The common problem is your SMSC setting. Go into messages, settings, smsc and make sure 16475800172 is the correct number.
If your sim works in another phone but changing the smsc does not help reset your carrier settings and clear all cache of your messenging app. If that still does not work do a factory reset, if it still does not work your phone has an issue we canno't help you with.
If your sim does not work in another phone you need to contact the moderator team and ask them to reset your sms service. Click this to message them.
03-22-2019 02:35 AM
What there any update the software. What is your text message center number set to?
03-22-2019 02:23 AM
What kind od phone are yopu using?
03-22-2019 01:36 AM
@frankindustries are you using iphone?
