Anyone know where to find the APN settings?
BabyBluez
7 REPLIES 7
@galen wrote:
that is not working for my phone. i have typed everything like it shows, i have a samsung S7.
and it is not working at all, i still can not send any texts what so ever.
 @vinnyc is right. Duh. Thanks for noticing that.
 @galen Maybe you're on the $10 plan and have used up all your allotment.
vinnyc
apn's are not needed for sending receiving texts/sms.
correct apn's are needed for sending/receiving media such as pics via texts, this is known as mms.
more info needed
Find your phone on this list:
Officially Recognized APN Reference
Which Android version are you on?
galen
hengland
Settings
Cellular
Cellular Data Network
APN
BabyBluez
Thanks Alex I just needed the correct APN for public mobile.
Alex888
@BabyBluez
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
