04-30-2018 02:19 PM - edited 01-04-2022 04:12 PM
The text function on my phone stopped working two days ago. Can't receive or send text messages. A message pops up saying the text will be sent wehn service becomes available again. What's going on? Data and voice seem okay.
05-01-2018 11:23 AM
@matbasm wrote:
@srlawren wrote:
@matbasm wrote:@TrevorPM, When you return fromthe US, sometimes texting does not work for a short while. Usually returns in about a day. You can try messaging the mods to see if they can force the system to correct itself. You can also try restarting your phone (if you haven't already).
@matbasm while true, not helpful since @TrevorPM already said they weren't travelling.
@srlawren, Actually, @TrevorPM did indicate that they just returned from the US. Perhaps you are thinking of someone else (or i am loosing it completely
@matbasm you're right, I was confusing Trevor with the original poster @ongbryan. It's confusing sometimes when someone else piles onto an existing topic instead of starting their own thread. My apologies.
@TrevorPM this has probably resolved itself by now--reboot your phone if you're still not getting inbound SMS messages and it should be working. If not, contact the moderator team via private message (see the link in @Mary_M's reply above) for help.
05-01-2018 09:21 AM
Hey @ongbryan,
thank you for posting on our community regarding your text messaging !
Even if, after all of the troubleshooting, your services aren't properly working, don't hesitate to reach out to us by private message, we can look into it for you 🙂
Cheers,
Mary
04-30-2018 11:46 PM
mine does this all the time. most of the time just restarting the phone solves it. im not sure why it does it though
04-30-2018 10:10 PM - edited 04-30-2018 10:47 PM
@srlawren, Actually, @TrevorPM did indicate that they just returned from the US. Perhaps you are thinking of someone else (or i am loosing it completely )
04-30-2018 07:31 PM
04-30-2018 06:26 PM - edited 04-30-2018 06:30 PM
Click here to send the moderators team a private message.
Information regarding the moderators team can be found by following this link.
04-30-2018 06:25 PM - edited 04-30-2018 06:26 PM
@TrevorPM there is a bug when you come off a roaming add on it should fix itself in a couple days or you can send a private message to the mods to fix it sooner
04-30-2018 06:22 PM
I'm having the exact same issue. Just returned to Canada from a trip to the US and was on a roaming plan. Did you find a fix?
04-30-2018 03:13 PM
Thanks. Texting has just come back on, as mysteriously as it vanished.
04-30-2018 03:05 PM
@ongbryan as strange as it sounds, try a different texting app from the Play Store, such as Android Messages, Textra SMS, Chomp SMS, etc.
04-30-2018 02:44 PM
Android. Did the reset but no luck. Thanks for your suggestions.
04-30-2018 02:40 PM
Thanks for your reply. I haven't been roaming, so I guess that's not a cause.
04-30-2018 02:37 PM
Are you using iOS or Android OS? Did you also try reset network settings?
04-30-2018 02:35 PM
No setting changes as far as I can tell. Haven't been out of the area. Thanks for your suggestion.
04-30-2018 02:33 PM
Yes. Turning the phone off and on doesn't seem to solve the problem.
04-30-2018 02:27 PM
@ongbryan Have you just finished a US Roaming text add-on? If so, this is bug that usually clears in a few days, or you can message the moderators.
04-30-2018 02:22 PM
@ongbryan, Has anything changed on your phone (settings, etc?). Otherwise, it sounds like something at the account level (since talk and data are still working).
I recommend you send a private message to the moderator team and ask them to investigate. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
BTW, any chance you were out of the country just before it started?
04-30-2018 02:22 PM
Did you try to turn off your phone and turn it on again? Maybe just a bug it'll go away soon.
