04-23-2022 09:30 AM
Why is my "congrats" message coming at midnight? It use to come at noon and now wakes me up every time? How can it be changed back?
04-23-2022 11:36 AM - edited 04-23-2022 11:36 AM
It was always like that, at last since 2021.
You can add 611 to your contacts and assign <silence> as notification sound and remove vibration.
04-23-2022 09:41 AM
@cmessier Yes, not a great time for notification. Used to be another time but PM changed it since last year.
I do not recommend you to block the notification as you would miss the important one (some of them are indeed useful)
I suggest you to add it to a contact, then select silent notification for this contact. In this case, the message will come but won't wake you up, you can go back and check the message
