10-26-2025
03:57 PM
10-27-2025
03:11 PM
computergeek541
Hi . I'm on public mobile service but I'm not able to use texting income out going. I have tried very on my side here from net work reset to restarting my phone check all my settings doing factory reset nothing seems to work on my side here.
***Message edited by CS_Agent to comply with the Community terms of service.
10-26-2025 05:03 PM
hi @Dustygk73
it is not uncommon, it could be a device issue
are you on iPhone or Android?
if Android, try to clear cache reboot phone and test again
if same, try to uninstall Google Message (it will show as uninstall update), reboot phone, and reinstall the Google Message and it will fix the problem
10-26-2025 05:01 PM - edited 10-26-2025 05:02 PM
@Dustygk73 wrote:I singed up in August 28 and work fine for a short time
So if it's just texting, that's odd. You can make and take calls I assume? What phone are you using?
Just wondering. Did you port over from a different provider?
10-26-2025 04:28 PM
10-26-2025 04:06 PM
Hey @Dustygk73
Click on the arrow up top in the box and remove your name and email address. These are not private forums.
Have you been a customer with Public Mobile a while? Did this just start recently? Did you just port over from another service provider? What phone are you using? More info will help us help you.
