02-09-2022 11:56 AM
I cannot text while I am in the USA even though my plan says I have international texting
Service
02-10-2022 11:39 AM - edited 02-10-2022 11:40 AM
Try to find WIFI hot spots that are just about everywhere. Hard not to find WIFI at hotels, department stores, restaurants etc.
02-09-2022 01:12 PM
02-09-2022 12:08 PM
As they say in the commercials…”Only in Canada” for the International texting and calling from Canada.
You need to purchase Roaming bundle for 10 days.
Other options is use wifi app or purchase a local SIM.
02-09-2022 12:06 PM
Correct. But you may have discovered that you can receive texts in the US without a roaming add-on.
02-09-2022 12:00 PM
Yes, you do unlimited domestic/international texting but only WHILE in Canada.
For US roaming services you have to buy add-on
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
02-09-2022 11:57 AM - edited 02-09-2022 12:01 PM
@wayne2354 You plan said international text is for you to able to text FROM Canada to other countries. NOT to use when you are out of Canada
Talk, text and data services refer to services offered while connected to the Telus/Public Mobile network. For service when not connected to the Telus/Public Mobile network, a roaming package must be purchased. Calls must originate from Canada to the US.
If you need text in USA, you will need to buy roaming add-on that has Text feature. here are the list of PM roaming add-in:
Bundle - US Roaming - Talk Text (10-day) - $15.00 (10 Reward points)
Bundle - US Roaming - Talk Text 250 Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 1 GB Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 250 MB Data (10-day) - $10.00 (5 Reward points)
Data - US Roaming - 500 MB Data (10-day) - $15.00 (10 Reward points)
Text - US Roaming - Unlimited Text (10-day) - $8.00 (5 Reward points)
Talk - US Roaming - Unlimited Talk (10-day) - $8.00 (5 Reward points)
Or download some VoIP app for free texting, like TextNow. Download the app, it will let you select a Canadian phone number. Then you can receive calls and text and make outgoing calls and text on the app as long as you have Wifi or Mobile Data in US (for mobile data, consider buying the local data prepaid plan in US)
