Text messages
09-02-2024
03:40 PM
09-03-2024
02:42 AM
computergeek541
09-02-2024 04:01 PM
Does other services work? ie talk and data?
Part 1:
imessage can sent to/from Apple ID or a phone number. To do what you described you should be using your phone number, not your Apple ID.
- Go to Settings> Messages> Send & Receive
- Your settings should be:
- Can be reached by imessage at: Phone Number
- Start new conversations from: Phone Number
Part 2:
Turn on Send as SMS
09-02-2024 03:44 PM
HI @Squirrelly7
the iMessage is the app to check all the text and iMessage
in iMessage settings, make sure you enable Send as Text and MMS messaging
