03-18-2022 08:00 PM
Hi,
I am with Canada-wide basic plan. I'd like to know if I can send and receive text message for free when I am outside of Canada. Can anyone provide me the answer? Thanks.
Hong
03-19-2022 01:50 PM
Thanks for the message
03-18-2022 11:15 PM
@hanliu2018 wrote:Hi,
Hong
Where you are going? roaming is expensive anyway. Use data SIM there and use Whatsapp or Skypes for calls. You can be fancy and use Fongo , but its voice quality is not good
03-18-2022 08:43 PM
@hanliu2018 wrote:I am with Canada-wide basic plan. I'd like to know if I can send and receive text message for free when I am outside of Canada. Can anyone provide me the answer? Thanks.
With an active Public Mobile plan, you can receive text messages while you're in the U.S. for no extra charges (no roaming add-on required). When it comes to text messages, the U.S. roaming add-ons mentioned are only needed for sending outgoing text messages.
03-18-2022 08:37 PM
PM only have Roaming if you are in USA making calls or texting.
Other countries, it is better that you purchase a local SIM from that country.
03-18-2022 08:18 PM
ALL PM services are while you are in Canada only. Only US has some limited time add-ons and PM will not work in any other country.
You can in/out SMS/MMS to everywhere in the world for free but only while at home.
03-18-2022 08:08 PM
Sorry you can only use your plan while in Canada or in the US with 10 day US Roaming add ons.
To pre-verify your account, provide your full name, address, your email, phone # and 4-digit account PIN#
03-18-2022 08:03 PM - edited 03-18-2022 08:10 PM
Not using Public Mobile, you can't. Soon as you leave Canada it'll stop unless you have one of the 10 Day US Roaming add-ons that will include text.
edit'd...spelling
PM will only work in Canada or USA (with roaming add-on). No other country included.
10 Day US Text add-on is $8 and will let you text anywhere while you're in US...for 10 days.
