Text image not downloading
crosbyoverovi
I have been having problems lately downloading text that are images. I have my mobile data on as I found previously that WiFi wouldn't download them. My phone is a Moto E4 if that helps. Any solutions? I have cleared cache already.
19 REPLIES 19
darlicious
@crosbyoverovi
Goodness this has gone from bad to worse.....after customer support fixes your sim card and your services are working which may fix your APN issue as well if it does not and you get the same message as before ask for a configuration file to be texted to your phone to set up your APN.
@crosbyoverovi
wait until see what support found,
if not fix it yet tried to do factory reset, but you need first to back up, if you needed for any contact or photos/videos.
crosbyoverovi
Unfortunately I don't have another phone handy to test the SIM card on. Thanks for the info!
@crosbyoverovi wrote:
Thanks for telling me how to undo the solution. Ya no, I can edit it whatsoever. It looks like I have to take it to a repair shop. Also, my sim card isn't working. It seems to have stopped working once the customer support person I was chatting with was in the back end of my account try to fix it.
@crosbyoverovi  - i'd open another ticket with CSA to tell them this. Escalate if to a supervisor if you have too.
There have been other issues (for over a week) that sound similar to yours.
If you have another phone to try your SIM Card into, also try that and test it (once public mobile support fixes what they broken, that is).
If the SIM card works in another phone try checking with Motorola support:
https://motorola-global-portal-en-ca.custhelp.com/app/mcp/contactus/
See what they say. One other member had a motorola too.
crosbyoverovi
darlicious
@crosbyoverovi
You can unmarkbthe solution by going to the little arrow thingy on tbe right side of the post.
You probably just need to edit the APN. Are you able to access the edit APN setting as set out in the instructions supplied in the link by @Timer ? I have seen that message you recieved about access unavailable....now I just need to remember where and how it was fixed?🤔
crosbyoverovi
No, I by accident hit the found a solution button. No still having problems.
darlicious
@crosbyoverovi
So you are all good to go now?
crosbyoverovi
My mobile data isn't the issue, it is working fine.
crosbyoverovi
It's an Android 7.1.1. Data works fine, I'm using it right now. No, it's not greyed out it just has that message on a white background.
darlicious
@crosbyoverovi
What is your OS? Oreo 8.i? This is unusual for a moto phone. When was the last time mobile data worked on this phone?
Edit:
Is the ability to edit the APN greyed out?
crosbyoverovi
It says APN settings are not available for this user.
darlicious
@crosbyoverovi
Check you APN it may have reset itself to default. This is the one on my moto g7+.....
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
crosbyoverovi
I've been having this issues for about the last 2 weeks. So, it's not just today.
crosbyoverovi
I stated that my mobile data is on already.
Timer
@crosbyoverovi
 turn on mobile data, and check your APN settings
and rebooting device.
Yummy
Actually few customers reported similar issue today.
I guess you did reboot and as you mentioned - DATA is On. Your phone is OK, nothing wrong with it.
I guess some PM server managing MMS is having some issues.
You can always ask agent for clarification and assistance. If you were able to receive MMS (images) before and you did NOT mess up with phone's settings then it has to be something on PM side.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
HI @crosbyoverovi  you meant MMS (multimedia message)?  You need to turn on Mobile data for MMS to download.
