11-27-2019 10:08 AM - edited 01-05-2022 08:09 AM
Can I text or call from Maui to Canada? Can I receive text or calls from Canada while in Maui?
11-27-2019 10:17 AM
@Rrempel4 wrote:Thanks, so just be clear calls and text can originate from the US with roaming $20 plan
Yes, they can.
11-27-2019 10:16 AM - edited 11-27-2019 10:16 AM
@Rrempel4 wrote:Can I text or call from Maui to Canada? Can I receive text or calls from Canada while in Maui?
The roaming add-ons mentioned are needed for calls and outgoing texts. Incoming texts work in the U.S. without a roaming add-on.
11-27-2019 10:15 AM
11-27-2019 10:13 AM - edited 11-27-2019 10:18 AM
You would need to purchase a US roaming add-on. There is a bundle for $20 which has talk/text and data for $20 and valid for 10 days from purchase. There is a $15 add-on for just talk and text.
