08-03-2023 09:07 PM
I need to cancel and get my 50$ refunded please.. my phone doesn't even work now with your carrier company. I don't receive calls, can't make calls or texts..
08-03-2023 09:45 PM
@Knotty if you just activated, it is just a sim card provisioning issue. It is an easy fix for PM and you just need to engage them via ticket here
08-03-2023 09:21 PM
That's it @Knotty , you give up already?
Indeed, if one shot and that's it, this place probably isn't the place for you. Perhaps you may wish to deal with a higher tier (and likely higher priced) company.
Try TELUS.
08-03-2023 09:16 PM - edited 08-04-2023 12:12 AM
Are you referring to customer service or reception?
It sounds like your account is suspended for nonpayment or a outage in your area. Dial 611 for the status of your account.
Check outage map:
https://istheservicedowncanada.com/status/telus/map
To cancel you PM service, just port your number to another carrier and will cancel right away
or login to your account and stop monthly payments by disable Subscribe/AutoPay and will cancel after 90 days.
Sorry no refund for any prepaid service in Canada like PM. The higher postpaid service will be prorated so this is what you will need to port over to.
08-03-2023 09:16 PM
@Knotty pM it ore paid no refunds . You ca cancel your account by listing out the number or turning off auto pay
Turn auto pay OFF/ON 3 easy clicks
Or if you know the 4 digit PIN number
*611
