Tennessee Cell Service
Tellico
I have great US roaming coverage but in Tellico Plains Tennessee I have no service for 20 miles. And there is towers and others have good coverage.
Chalupa_Batman
If you're really gung ho on using your plan while in the US, follow the solution. However, if you're going to be there a bit, might want to consider this. Just to note, you must be IN the US to view this and be on a US IP address. Or a VPN might help.
https://www.t-mobile.com/offers/free-trial
hi @Tellico
confirm the T-MOBILE coverage here
https://www.t-mobile.com/coverage/coverage-map
And try many select T-MOBILE network on your phone
@Tellico  Just make sure you’re connected . To T mobile and reboot the phone and text in different areas is all you can really do
