02-17-2021 04:43 PM - edited 01-05-2022 05:19 PM
Hi. Suddenly I get a message saying I am not a registered user when I try to make a phone call. What is the problem?
02-18-2021 11:50 AM - edited 02-18-2021 11:54 AM
@Lab1 wrote:I cannot log in to self service but was able to check the status of my SIM card on my phone and it says not connect; emergency calls only; out of service. Help!
Hi @Lab1 did you also check if the last 4 digit number of your sim card in your self serve account, the same as the last 4 digit number of your sim card, as suggested by @HALIMACS ?
If they are not the same, you'd been sim jacked. Contact the Moderator Team using the links provided in @HALIMACS post above.
RosieR
02-18-2021 11:50 AM
How long have you had that phone ? If you just got it recently...where did you get it from ? When did your last renewal occur ?
02-18-2021 11:50 AM - edited 02-18-2021 11:50 AM
Do the 19 digits on the SIM card in your phone MATCH the digits on the SIM card registered on your self-serve account, @Lab1 ?
If not, please follow earlier advice.
If you continue to have problems, you may wish to contact a Public Mobile moderator:
To contact a moderator, there are 2 methods:
02-18-2021 11:47 AM - edited 02-18-2021 11:49 AM
Can you try logging into self service again. Clear browser cache. Close browser and open a new window in incognito/private.
Take your SIM card out and reinsert it and reboot.
02-18-2021 11:45 AM
02-17-2021 04:49 PM
@Lab1 wrote:Hi. Suddenly I get a message saying I am not a registered user when I try to make a phone call. What is the problem?
Please check this, @Lab1
In your self service account, choose Change Sim Card.
Ensure the last 4 digits on the self-serve SIM number match your SIM card to ensure you have not been sim jacked.
If they do not match, while still on the self-serve account, put your phone in lost/stolen mode and change the password. Then check and secure all your financials.
From, there, contact a moderator, there are 2 methods:
02-17-2021 04:45 PM
