Talk not working
Dlysh113
PM called me with a 001 number saying talk is not available for my plan but I am currently on the $40 plan and checked on my self serve. Is anyone else getting this?
8 REPLIES 8
Dlysh113
Yes, my dial out works however I keep getting phone calls saying my talk doesnt work from PM. Weird, perhaps a scam.
Do you mean that you were trying to make a call but heard that errror message?  If that's the case, were you trying to call a non-Canadian phone number?
Lowufo
@totalUser wrote:
@Lowufo wrote:
@totalUser wrote:
Cab you
Cab you ???? hunnnh
Sorry my phone froze then sent it out while I was trying to correct the spelling, I managed to correct it
Figured it was something like that Smiley Very Happy
@Lowufo wrote:
@totalUser wrote:
Cab you
Cab you ???? hunnnh
I wish I could like this twice, lol.
Luddite
Very unlikely PM called you. If you phone is working normally ignore it. Otherwise, tell us what is wrong with your service.
@Lowufo wrote:
@totalUser wrote:
Cab you
Cab you ???? hunnnh
Lowufo
@totalUser wrote:
Cab you
Cab you ???? hunnnh
totalUser
Can you please login to your self-serve advd check your status.
Does your dial out work?
Try dialing a known number to see if that works, try 611 or voicemail
Please don't respond to it, if concerned connect with moderators
