08-31-2018 03:07 PM - edited 01-05-2022 05:33 AM
Hi members,
I have a question. I want to downgrade my data+text+talk plan to an only $25 talk+text plan. My question is: Can I add the optional $30 dollar 1gb add on to this $25 talk+text plan? Will it stay in the account until I finish all the data up? Roll over to the next month is what I mean.
I don't use any data. And I will only require it when I need it.
Also is Call Forwarding to a Canadian Number possible also?
Please let me know if it's possible. Thanks.
08-31-2018 03:41 PM
@Elturco wrote:Hi members,
Yes, the data add-ons can complement a talk&text only plan. It's what I did for more than a year (my data needs have changed considerably recently so I switched to one of the promo plans...) - my first data add-on lasted just short of 10months. I also added the 400min LD add-on for the odd out-of-province call.
With the current plan line-up it's more cost effective to go for the $30/500MB plan if you consistently use more than an average of 170MB per month.
08-31-2018 03:17 PM
@Elturco Yes, you can buy the data add-on and it will not go away until you use all of it. and yes, call forwarding is available.
