Talk Minutes
04-11-2023 08:02 PM
Hello. I am a new Public member and have unlimited talk minutes. While talking with a client, my call was discconnected and a message said I was out of minutes and to press 611 to purchase more minutes.
I re-dialed and was able to resume my call.
How can I ensure this does not happen again?
Plans
04-12-2023 11:56 AM
My previous provider was Rogers.
04-12-2023 05:04 AM
Who was your previous provider? That's a strange glitch I have never heard of before? Even with the $15 plan pm doesn't give a voice message rather you get a text saying "You have 10 minutes remaining in your plan". It will only cut you off if you don't have an applicable calling minutes add on.
04-12-2023 12:55 AM
Agreed. Hopefully it's a one-off!
04-12-2023 12:22 AM
That is odd then. I understand dropped calls, but to say you're out of minutes is bizarre.
04-12-2023 12:16 AM
Correct.
04-12-2023 12:13 AM
No, I'm definitely not on the $15 plan. I signed up for the 15GB data/unlimited talk plan and the Public portal confirms that they set it up correctly.
04-12-2023 12:12 AM
Thanks. I re-dialed my call immediately after it was terminated and it worked fine.
I opened a ticket as you suggested and am awaiting a response.
04-12-2023 12:09 AM
04-11-2023 11:15 PM
Yeah my guess is you're on the $15 plan which was incorrectly advertised as having unlimited minutes, but it actually only has 100 outgoing minutes and unlimited incoming.
04-11-2023 09:48 PM - edited 04-11-2023 09:50 PM
Perhaps so.
To be certain, your call originated within Canada and was received within Canada? ( i.e. by a Canadian number )
04-11-2023 09:47 PM
@garymk reboot the phone once, then make a call by putting a 1 in front of the 10 digits number. So if you can sitll make the outgoing calls. If you can, it is just a hiccup. If you still cannot make the call, you might need to open ticket with PM support to confirm your plan details
04-11-2023 09:45 PM
Thank you for your reply. Dropped calls can happen with any provider but before my call was terminated, I was told that I had run out of minutes and I had to purchase more. Clearly, the Public system erroneously treated my account as not being unlimited talk minutes for whatever reason.
04-11-2023 08:06 PM
This certainly should not have happened, however I personally, and other users, have reported after very lengthy calls sometimes the network drops the call.
Are these calls happening while you're on the move and possibly running into reception issues in tunnels or between large buildings?
If this is not the case, definitely let the customer support agents know that you must not have dropped calls.
- Use the ticketing system for a faster response time. Click here to create a support ticket, or,
- Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
04-11-2023 08:04 PM - edited 04-11-2023 08:06 PM
log in on a laptop and make sure you still have minutes...maybe you're mistaken and on the $15 plan with 100 outgoing minutes but Unlimited incoming.
Try this...
Otherwise...that's a glitch that I've not heard of.
