Tablet
Grahamk
I need a data plan for my Ipad 3G for 1 month while I am out of wifi range. If I buy the $40 plan and put the sim card in my Ipad for data use only, can I then move the SIM card to my Google Pixel and continue the $40 service plan going forward?
Daphne1
Yes, the Public Mobile sim card is transferable from device to device. Your devices should be unlocked, they cannot be locked with the previous carrier.
mimmo
@geopublic  the only issue with this option, is the tablet will think its on wifi and might download updates.  Not sure if the iPad has a metered connetion mode to stop downloads/updates.
geopublic
@Grahamk  Another option is to use the sim in your Pixel and turn the hotspot on so that your ipad can connect.
GinYVR
@GrahamkYes as long as you have a voice plan then you can have voice service on your Google Pixel.
