TRANSFER NUMBER FROM PREVIOUS PROVIDER
bhalajisiva
 @Moderator_TeamHello,
While porting my number from lucky i provided a wrong password from my previous service provider.Now my public mobile sim is not working.Can you please help me with this issue?
surreyboz
Lucky Mobile doesn't use Password/Pin Numbers so did you just make up a random number?.  Even then your Public Mobile SIM Card should still work for outgoing calls & data.
will13am
@bhalajisiva, the moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
ShawnC13
You will need to contact the moderators for assistance as already stated by others.
To send a private message to a moderator click this link and describe your issue.
Community Moderators are available from Monday-Friday 9am(Eastern) to 9pm(Eastern) and Saturday, and Sunday from 9am(Eastern) to 7:30pm(Eastern) More info on moderators
Murco
You can send the mods a direct message with your info.
You're going to have to send them a private mesaaage about this.  This is partly to make sure that the account is yours and so that they can make sure that work is being done on the correct one.
