Switching plan/subscription: Public Rewards or Public Points program?
vancity_planner
I am a Public Mobile customer since 2017 and I was on the older Public Rewards program.
I am currently on the $40/month 15 GB 4G 30-day plan and I would like to switch to the current promotion of $39/month 20 GB 4G plan. If I do this, will I automatically be enrolled into the Public Points program or will I still need to opt in from my existing Public Rewards program?
Kelvin_HellBoy
Be careful to check more ...more...more.. before to switch. Because, no one can join the OLD publice Rewards program. May be this is a trap
Kelvin_HellBoy
Hi,
If I already mindlessly switched to Public reward program, can I cut down my lost to switch my $25 plan to $15 plan? Will I keep all my add-ons holiday gifts?  Will I keep in Public reward program after I downgrade to $15 plan?
Dunkman
@vancity_planner
No worries. You can switch to any plan.  It will not automatically switch you to the Points rewards program.  You will need to separately manually switch (not recommended - stay with old rewards program).
