@iraahmed you had your service working perfectly before (incoming and outgoing calls and text and mobile data), then you go to Change Number to change a new number and cannot make any outgoing calls?
or you meant you port into your number from another providers and have problem?
If it is the first situation, I guess you already rebooted the phone many time. Do you have another phone to test putting your PM SIM into there and test?
If still fails, open ticket with PM Support :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
If it is a porting issue, then you should have incoming calls problems and not outgoing
