Switching back to my Nexus 5
11-05-2016 12:30 PM - edited 01-04-2022 01:11 PM
I want everyone to keep their fingers crossed. I'm switching back to my Nexus 5, leaving my iPhone 5s in the dust.
its been a long while since I've used the Nexus 5. I'm running Marshmellow. Already installed WiK's Data Witness.
Looking forward to this!
Phones
11-07-2016 07:27 PM
I actually make use of these suggestions already. I came home with 44% battery remaining this afternoon. I can handle that.
11-07-2016 06:27 PM - edited 11-07-2016 06:28 PM
There's a few things you can do to save the OS from burning through the battery.
1. Turn off Wifi Scanning and Bluetooth scanning.
2. Disable location history.
3. If you have the setting, turn off cell alerts. AFAIK, we don't have this in Canada.
4. Disable syncing of google services you don't use. By default, Google enables everything to sync. incl. Chrome bookmarks to Google Fit Data to Play Books and Movies. Turn off those you don't want.
5. If you don't use GPS much, turn GPS to off.
6. Disable notifications and phone home settings in your apps. Some apps have their own push/pull notifications which can cause the device to wake up.
7. Turn down the display brightness - esp. at night.
Keep a close eye on the battery graph in Android. Ideally, it should be almost flatline if your device is asleep (not in use). The horizontal bars for Wifi and Awake should almost match that of the Screen except for certain small marks when Google wakes up periodically. If you have huge sections of Wifi and Awake bars where the Screen does not, something is not right.
EDIT: If you have wifi scanning turned on, your WiFi bar will be solid regardless of the Screen On bar.
11-07-2016 06:11 PM
11-06-2016 12:47 PM
Yes, I see the poor battery life also. I was thinking of getting a replacement battery. I'm just not sure if that's going to be most cost efficient or not.
11-05-2016 09:16 PM
The one complaint I have with my Nexus 5 is battery life. It's pretty horrible...can't get more than 90 mins of screen time without it dying. Moving to a used LG G4 soon.
11-05-2016 06:32 PM
11-05-2016 01:01 PM
Been using Nexus 5 since i joined Public Mobile. It works just fine as long as you don't watch lot of videos or play games. For simple use like calling/texting/surfing, it should be your daily driver.
To make it even better/faster, look into custom rom, but i do not recommend if you're not familial with installing/flashing. I recently installed one of the marhsmallow rom and its been fantastic so far.
