10-25-2022 02:04 PM
Hey all.
I’ve been a customer for a while. I switched plans and the new one kicked in on Monday. As soon as it did, I haven’t been able to send/receive emails or access data - these services worked on Sunday.
So far I have…
- reset my network settings
- tried the sim in another phone
- checked and confirmed my APN is correct
I’m frustrated and concerned - I essentially have a paperweight when I’m not able to access wifi.
10-25-2022 04:57 PM
@dt87 wrote:Of course! I opened another ticket and requested them to confirm my new plan was active.
I was advised to shut my phone off while on their end they “reset” and double checked the provisions. I hope this helps 😊
Thank you very much for feedback. I am sure most guys here are happy you managed to resolve your issue (with our suggestions!).
10-25-2022 04:47 PM
10-25-2022 03:54 PM
@dt87 wrote:Sure enough - it wasn’t a problem on my end. Thanks for replies and suggestions everyone. It’s fixed.
Great.
Would you mind to tell us what fixed your no data issue so that other members can learn from it?
10-25-2022 02:41 PM
10-25-2022 02:39 PM
@dust2dust wrote:@softech- They said they tried in another phone. It's helpful to read the entire question. 🙂
He, he. It is easier to copy/paste 😋
10-25-2022 02:38 PM
@dt87 wrote:Thanks. I was messaging with one over the course of about 4-5 hours last night. The one suggestion I haven’t tried is to get a new sim. It seems like it’s a plan issue.
You did a thorough testing.
1. Did CSA reset your connection before asking you to get a new SIM?
If you are in Calgary, I can give a free new SIM card. Private message me for pickup location if you live in Calgary.
2. Did you switch to a 4G plan?
If yes, is your phone support LTE signal?
Make sure to restart your phone with any changes.
10-25-2022 02:24 PM
As the only thing that’s changed is my plan - I think I am inclined to agree. I’ve messaged and asked that it be clarified that the plan is activated.
10-25-2022 02:18 PM - edited 10-25-2022 02:22 PM
@dt87 so, a PM support suggested that? Reply and ask them to reimburse the cost 🙂
But honest, it doesn't look like a sim issue. Only reason it might work on a new sim card is that the sim/account will be re-provisioned and corrects the issue
10-25-2022 02:15 PM
10-25-2022 02:14 PM
10-25-2022 02:13 PM
you tried the service in another area? not sure if it is local neteork issie.
and try to change the Preferred network to 3G ONLY to see if it works
you might want to open ticket with PM support and have them check the account
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-25-2022 02:10 PM - edited 10-25-2022 02:11 PM
@dt87 wrote:Hey all.
So far I have…- reset my network settings
@dt87hi when you switched to the new plan it may not have set up properly you need to contact a customer service agent and get them to look into it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-25-2022 02:08 PM
I can make calls but that’s it. Same story if I switch phones.
10-25-2022 02:07 PM
@dt87 voice working?
You tested your service in another area?
do you have another phone to test the sim?
Even you don't have another phone around, please try to reseat sim card
