03-13-2021 10:51 AM - edited 01-05-2022 05:36 PM
Hi everyone,
my account has enough fund but it’s not working the problem might be fraudulent activities because I tried to renew my account on my sister phone
anyone has a solution?
Thanks in advance
03-13-2021 12:16 PM - edited 03-13-2021 12:17 PM
Dial 611. If you connect you need to reactivate your account. If your number cannot be completed as dialed then be worried. Log into your account go to the plans page and suspend your service via lost/stolen. Change your password and contact the moderators.
03-13-2021 11:15 AM - edited 03-13-2021 11:17 AM
@Nahidkazemi1353 wrote:Hi everyone,
Thanks in advance
Do you suspect you have been SIM hacked? What happens when you call your number from your sister's phone? Try your SIM card in HER phone to make/receive calls. Can you? If you can log into your self-serve, does it say "Active"?
Try rebooting, removing and replacing SIM card, resetting network connections.
Please review the following article and take measures contained therein if you believe you may have been SIM swapped:
03-13-2021 11:05 AM
More details may be helpful. Moderator response times are usually several hours. Sometimes community members (customers like yourself) can provide solutions.
If your account status active or suspended?
Does anything work? Text, talk and data?
When was your renewal date?
Maybe try rebooting your phone. Network reset. Remove SIM card and re-insert.
03-13-2021 10:53 AM
Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
