11-07-2022 01:11 PM
Trying to contact customer support. signed in acvount. chated wth robot
Could not submit ticket with 404 error
send privae message did not go anyhere
signed in community it just goes to questions and answeres .
ne hourr has passed can not communicate
with customer support even if I had done it before but it is not working
Service
11-07-2022 01:28 PM
Thank you issue was to contact.
11-07-2022 01:16 PM
HI @NG5 how long you sent the private message? It usually take maybe 2 hours for them to reply. Yes, it could be longer
Also, did you check your Community inbox? PM agent reply there
If you have submitted long enough, message them again
11-07-2022 01:15 PM
He has another thread.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Slooow-system/m-p/900764
11-07-2022 01:14 PM
hi all help is online is there anything we can help with?
private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
11-07-2022 01:13 PM
@NG5 if you already tried the chatbot and didn't work, just private message them directly
But one question, what is the issue you have now? maybe share here and hopefully we can help
11-07-2022 01:13 PM
@NG5 Share your issue.. someone here can probably help
