Support for Samsung Galaxy XCover Pro?
IanFalk
I was thinking about changing phones but can not find info on whether or not the Samsung Galaxy XCover Pro was supported.
Will this phone work on Public Mobiles network?
Any help with this topic would be really appreciated.
TheGx
@IanFalk :Also you can use the phone compatibility tool in future by click the activate SIM at bottom screen then click check my phone.
IanFalk
Thank you Dunkman for the quick reply
Dunkman
@IanFalk
This phone will work with Public mobile.
Here are the specs:
https://www.gsmarena.com/samsung_galaxy_xcover_pro-10001.php
3G bandsHSDPA 850 / 900 / 1900 / 2100 - International
 HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - USA/Canda
4G bands1, 2, 3, 5, 7, 8, 20, 28, 38, 40, 41 - International
 1, 2, 3, 4, 5, 7, 12, 13, 14, 20, 28, 29, 30, 38, 40, 41, 48, 66 - USA
 1, 2, 3, 4, 5, 7, 12, 13, 14, 20, 29, 38, 40, 41, 66 - Canada
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).   B2, B5
3G = 850 (5), 1900 (2)
4G = 850 (5), 1900 (2), 700 (12/13/17/29), 1700/2100 (4), 2600 (7), 1700/2100 (66)
@IanFalk   Yes, XCover Pro is a Canadian phone and can be found on Samsung.ca
here is the spec for the phone"
  • 3G UMTSB1(2100), B2(1900), B4(AWS), B5(850), B8(900)
  • 4G FDD LTEB1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B12(700), B13(700), B14(700), B20(800), B29(700), B66(AWS-3)
here is what PM has
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
