Subscription
Bbchild
My payment was taken but not credited to account
@Bbchild , you might not be seeing updated information due to data caching.  Trying viewing your account in incognito mode if using a browser and clear data if using the mobile app.  The surest way to check that the renewal was successful is by confirming the service is still functional.
HI @Bbchild
is it for plan renewal?  if your service does not work, try to reboot the phone and reset network settings.  Try both voice and data
and also, when you check your My Account, use Incognito/private/secret mode on the browser to login
if still have problem , ask PM support agent.  Submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
if you login to My Account, go to Payment history, does it show PM took the money ? did it show if PM used the money for renewal?
