03-03-2024 04:45 PM
05-19-2024 05:54 AM
I got step 4 for payment but error message "Postal code not ..." or "Credit card not validation ..."
03-03-2024 04:53 PM
@AliG1 wrote:I am using the app
you can try to uninstall the app, and reboot and reinstsall and try again
if same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-03-2024 04:53 PM
HI @AliG1
you need to be using the Public Mobile app for step 5 if you have not done so. Please download the app, login and complete the activation using the app
03-03-2024 04:52 PM
I am using the app
03-03-2024 04:51 PM
Payment successfully made can't get to step 5
03-03-2024 04:49 PM
HI @AliG1
can you tell us more details what happen and which steps you are at?
are you using the app to subscribe? If not, you need to download the app and use it to subscribe
you got to step 4 for payment and payment successfully made?
you got to Step 5 for phone numbeR?
and you got error at Step 6 for final activation?
03-03-2024 04:47 PM - edited 03-03-2024 04:47 PM
To submit a ticket, start with the chatbot at the bottom right corner.
Or the following link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
What part were you stuck at? Were you using the App to sign up as it's needed.
How to sign up with Public Mobile
