06-23-2023 09:29 AM - last edited on 06-24-2023 01:10 AM by computergeek541
M I need to speak to an agent regarding available subscription promo and best subscription suggestions. The one I’m currently using isn’t very good.
06-23-2023 09:43 AM
In the "Shop" section of the site there are a lot of plans to choose from. if you contact a CS_Agent they will most likely refer you to this.
06-23-2023 09:42 AM
@Jasmine_25 There’s a promo plan right now 20GB for $39 . Just make plan change for next renewal and not immediately or you loose money on your current cycle
06-23-2023 09:41 AM
check the plans here
https://www.publicmobile.ca/en/ab/plans
The best one in terms of the price is the $39 plan for 20GB. I belive you are now paying for $35, so it is just $4 difference and you have a lot more data. Start with that one, I think
There is another good one for $44 - 30GB if you need a lot more data.
So, both $39 and $44 plans should suit your needs
06-23-2023 09:39 AM - edited 06-23-2023 09:42 AM
Yeah sorry the agents are very hard to get hold of but you can try the chat bot
06-23-2023 09:38 AM
Thank you from the explanation. And I use more data and my current plan only offer 3GB per month which isn’t enough for me
06-23-2023 09:35 AM
You can send a message to CS_Agent by clicking on the mail icon on the top right corner. As for suggestions, what is your usage like? Do you use a lot of data and talk, or not much on a monthly basis?
06-23-2023 09:32 AM
@Jasmine_25 this is the community, we are customers like you . Maybe you can share your situation and we can advise
or if you like, you can of course message support and discuss with them
