Subscription not activated
Kerrie09
I'm trying to transfer from Koodo with a physical SIM and I'm getting a message saying "Subscription Not Activated". I'm not sure what I'm supposed to do next as I'm being directed to contact a customer service agent which then redirects me to ask a question in the forum.
1 REPLY 1
fixin1
@Kerrie09 - If you are porting from Koodo Prepaid, you will need to contact CS_Agent.
If you are porting from Koodo Postpaid (If you ever financed from Koodo you will have postpaid)
But either way, you can contact CS_Agent and they should get in touch with you, just check your messages tomorrow as they should be in touch tomorrow:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article!   ⚠️
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
